Block SNMP Access
Disable SNMP by using the SNMP block flag. By default, SNMP access is enabled.
    enable
    configure terminal
  2. Disable SNMP access:
    boot config flags block-snmp
The following table defines parameters for the boot config flags command.
Variable
Value
block-snmp
Configures the block SNMP flag as active. Use the no operator to remove this configuration. The default is off. To set this option to the default value, use the default operator with the command.
